I am about to purchase a whiteline handling pack
it comes with front and rear adjustable sway bars,
front castor kit and rear camber kit.
my question is which bushes r included in the handling pack, from my understanding the sway bars come with bushes
are there any other bushes that i should replace while the skyline is out of action?
has anyone fitted one of these kits to their skyline by themselves (i have 93 r33 gts-t)
cheers
https://www.sau.com.au/forums/topic/29569-whiteline-handling-pack/
I've got the Whiteline swaybars and bushes. They give you new bushes and linkage arms for the rear, and new mounting bushes for the front, but for the front you need to re-use the original linkage arms and bushes to connect them to the suspension arm.
The other bushes are rear suspension arm bushes to reduce camber, and new front castor rod bushes to increase castor.
The fronts are pretty easy to do, just take the radius rods out and take them to a suspension workshop to press the old bushes out and press the new ones in (cost around $20) and then just put them back in the car and get a wheel alignment done.
The rears I haven't tackled yet because it looks a lot more complicated. I think there are 4 bushes per side that need to be pressed out, but you have to remove the whole suspension arms to do it. Once they are out it shouldn't be too hard to get them pressed out and in like the radius rods.
Are you talking about the castor and rear camber bushes only? If so then I would get them. I've yet to put my rear camber bushes in but I know it'll improve rear traction when I put them in.
The castor bushes improve the feel of the steering, it will make the steering a bit heavier but it will feel a lot more solid, like you can more easily point the car in the exact direction you want to go. More like a racing car feel :)
If you mean other bushes (sorry I'm not up to speed on what's in the current kit) then I can't say because I don't have any others. I imagine a front camber kit may be useful, not as useful as the rear though because there's no power to my front wheels. May be more useful on a GTR but even then you're not using the front wheels constantly for power.
I have had the handling pack on an R33 GTSt before and it is great ( car had standard ride height, wheels and dampers and springs), and it transformed it. I got it installed on seperate days, and I can tell you the swaybars made the most dramatic difference, particularly the rear one. I believe the castor, camber kits may come into their own if the car is lowered, but I didnt notice must of a difference on my standard ride height car. Maybe look at getting pineapples (whiteline call them KCA???) at the same time as they arent very expensive.
Paid $700ish and $150 labour (included alignment) 18 months ago from Tru Track in North Melbourne, would highly recommend them. Ask for Ralph, he is a funny bloke.
The camber kit is only for if you lower the car. At the standard height the camber is correct. I would say that installing the camber kit without lowering it would be detrimental to handling.
Hi guys, the front and rear camber kits are adjustable, so you can set them wherever you want. So it doesn't matter whether the car is lowered or not, you can both add or subtract camber.
Hi rs73, the standard shocks are "already pretty good" but you are changing them. What makes you think that the swaybars are different?
I absolutely guarantee you that a Skyline with standard springs and properly adjusted stabiliser bars will out handle a Skyline with upgraded lowered springs and standard stabiliser bars. Every time.
Hm, I think you might be right... I talked to whiteline and the guy there recommended that I actually start with the stabiliser bars front & rear first.
Maybe I got it wrong the other way around when was told to change the shocks only not the bar....
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
