hey All
Deciding to sell my R33 GTR V spec 1995 model
Has 113,000 k's
11 months NSW rego
std GTR rims with brand new Kumho tyres
Apexi air filters
Apexi AVC-D
blitz boost gauge
looks to have Ohlins suspension in it, also has ohlins manual from Japan in japanese though
Also have factory owners manual from Japan again in japanese
Alpine radio and has TV with manuals in japanese havent had tv working
exhaust with 5 zigen muffler
Really nice car to drive. I imported from Japan not too long ago but looking to get a new 4wd ute so unfortunately has to go as my old ute has had it.
White in colour. Has small ding in passenger door as seen
front and rear strut braces
Interior clean seats good has wear marks on wheel and gear knob as usual
Looking for $22,000 for it not after trades or swaps sorry unless its a new navar 4WD ute!!
I am in Sydney just moved here though car 2 1/2 hrs sth sydney but can organise inspections etc
Rgds
Daniel.
https://www.sau.com.au/forums/topic/295818-fs-1995-r33-gtr-v-spec-22000/
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
