Hey guys I have this for immediate sale:
Blitz SBC Spec R (Dual Solenoid Boost controller)
Uses the same Solenoid as the Blitz SBC ID - III (I have both, upgraded to the ID -III because it shows more information on it's display.), Blitz Dual Solenoid Boost Controllers are renowned for being some of the most accurate on the market :P
The Dual Solenoid Boost Controller Spec R (DSBC Spec R) has four programmable boost settings or various levels of boost. This unit features a built-in boost gauge, peak boost display, four different boost settings, boost warning, scramble boost, and a boost limiter safety feature to prevent over boosting. The DSBC Spec R uses a dual solenoid design for maximum boost response. This unit is capable of handling boost up to 2.5bar (36psi). The DSBC Spec R is 1/4 din in size and is compatible with internal actuators and external wastegates. This unit is available in a silver case with an green LCD display. The difference between the DSBC Spec R and Spec S is the solenoid design. Spec R uses dual solenoid while the Spec S uses a single solenoid design.
*Note: Model on Nengun has an updated look from the one that I am selling, the information above is taken from the "updated look" model on Nengun and so may not be exactly applicable to the one that I am selling. From my experience with the unit it sounds very similar.
Nengun price AU $473.75: http://www.nengun.com/blitz/sbc-spec-r-dual-solenoid
Condition: Used, Good.
Asking $280 + Delivery costs.
Also have the following items up for sale when I get my car back, approximately 2 weeks:
Blitz Racing Meter DCII - Boost (Gauge) - Blue:
The electronic Racing Meter DC (Digital Compact) II series are one of the most unique gauges on the market. Succeeding its predecessor, Racing Meter DCII maintains the traditional dimensions and versatility of the Digital Compact Series - Featuring a depth of less than 1-inch and weighing 38 grams, the Racing Meter DCII can virtually be mounted anywhere in the vehicle. 60mm Diameter.
- Peak Hold: Peak hold can be shown all at once or by individual gauge.
- Record and Replay: Can record and replay up to 99 seconds.
- Warning: All you to set the warning for the gauges.
- Mode: The DC Meters has 3 different needle modes, real time, delayed mode and pass and hold mode.
- Contrast Adjustment: Allows the owner to adjust the contrast.
Nengun Price AU $ 245.08: http://www.nengun.com/blitz/racing-meter-dc-ii-boost
Asking $100 + Delivery Costs
Needs to be coupled with:
Blitz Racing Meter - Live Unit II:
Live Unit: The Live Unit can control up to 3 gauges; boost, temperature and pressure. The Live Unit also has an addition temperature sensor outlet, this will enable the user to purchase an extra temperature sensor and let the Temperature Gauge read two different readings.
Nengun Price AU $ 154.52: http://www.nengun.com/blitz/racing-meter-live-unit-ii
Asking $60 + Delivery
*I am unwilling to separate the Boost Gauge and Live Unit, as they will only work together*
Rays Engineering Dura Wheel Nuts - Regular Type - Blue:
These do not come with Lock Nuts.
Just like their wheels, some of the lightest wheel nuts in the world, perfect for your TE37's :P
JJR Price AUD $275.00: http://justjap.com/store/product.php?produ...at=0&page=1 (No listing on Nengun, only Short or Long type.)
Condition: Used, average (See picture above, rattle gun damage.)
Asking: $90 + Delivery
I will post more pics of the actual Boost Gauge, Live Unit and more of the Wheel Nuts when I get the car back :)
PM me if you are interested.
harts.
https://www.sau.com.au/forums/topic/296112-blitz-sbc-spec-r-and-others/
euroequip:
No box, just the packing box that it came from japan in. English installation and usage manual: http://www.blitzpowerusa.com/techsupport/p...sbc_specs-r.pdf
I hope this helps :(
harts.
Boost Gauge & Live Unit Pics:
Boost Gauge needs to be zero'd when it is installed, following the procedure found at the bottom of the last page in the Blitz DCII Manual, found here:
http://www.blitzpowerusa.com/techsupport/pdf/rm-dc2.pdf
It reads:
Note: Regarding the Boost Meter.
There are times when the needle/pointer on the boost gauge may not return to 0 after the self test.
To "Zero" in the gauge, hold down PEAK and REC switch on the boost gauge when you turn on the ignition. All L.E.D.s will light up. Use the PEAK button to raise and the REC button to lower the needle/pointer to the proper location. Push the MODE switch to exit programming and return the gauge to real time monitoring.
harts.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
    • Welcome!  Can't go wrong with a Stag.
    • Looks good. Nice height.
    • Hey all, a little help from the Stagea hive mind plz.. I'm days away from buying either a 2002 Stagea 250tRS AR-X Four, premium leather, power seats and all the old switches etc that go with it, or a 2002 Stagea 250tRS VR-X Four AERO, pov pack, cloth seats etc, with coil overs, sports zorst, comes with original zorst and suspension and parts. (I think I've got the models right?) Both are VQ25DET, have 160000kms, both straight no rust both with $2000+ in recent servicing receipts, both ride on aftermarket 18" rims. The Aero has a replaced turbo as well. I like the cool factor of the Aero car but the AR-X has never been modified. Neither have been driven hardly at all in the last 5 years. Any thoughts on which one or does it come down to personal preference? davemoto
