How to convert DVD to portable devices?
DVD video Converter software programs are handy tools to convert DVD to portable devices. Different DVD converters are with different functions but most of them can rip DVD to video of various formats. Leawo DVD Ripper is one of these DVD to Video Converters with functions to improve the video with video trimming, cropping and effect adjustment.
How to use Leawo DVD Ripper?
This DVD to Video Converter is easy to use. If there is no video improvement and customization, just with video import and export will do the job.
Let's see how to convert DVD to video for portable devices with Leawo DVD Ripper:
Step 1
Insert the DVD disk into the DVD drive, open the program and import the DVD files.
Step 2
Do the settings:
1. In Subtitle, select the subtitle language.
2. In Audio, select the language of the audio.
3. In Profile, select a video format.
4. In Output, set your destination folder for the output file.
Step 3
Click "Customize" to customize the video in your desire.
a. Effect adjustment:
Drag the slides for Brightness, Contrast, and Volume to improve the video quality.
b. Drag the buttons on the slide to trim the video or change the values directly in the Start Time and End Time.
Step 4
Click the big button to start the conversion.
dvd ripper | dvd to 3gp | dvd to apple tv | dvd to avi | dvd to flv | dvd to iphone | dvd to ipod | dvd to mp4 | dvd to psp | dvd to zune |
https://www.sau.com.au/forums/topic/296507-convert-dvd-to-portable-devices/
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
