SELLING A MANUAL GEARBOX R32 GTR BEEN RECENTLY PULLED OFF. SORRY I DONT HV ANY PICTURES OF IT BUT IT COMES TOGETHER WITH THE GEAR STICK WITHOUT THE KNOB. SELLING ONLY THE GEARBOX IF U WANT THE CLUTHCH PLATE ITS SEPARATE. ITS AN UPGRADED CLUTCH PLATE NOT SURE OF WHAT BRAND. BUT WILLING TO LET IT GO FOR $500. THE PRICE FOR THE GEARBOX WOULD BE $2000 FIRM. CALL ME IF U HV ANY INQUIRIES. WILL NOT POST ONLY PICK UP. CAR HAS DONE ABOUT 130000 KMS REZA 0432415424.
HAVE HEAPS OTHER PARTS AS WELL, INCLUDING DRIVE SHAFTS, CROSS MEMBER, STARTER MOTOR, FUEL PUMP, FUEL TANK, STOCK SPOILER, BOOT, LEFT FENDER, BOTH DOORS, WINDOW MOTORS, AFTER MARTKET EXHAUST NOT SURE WHAT BRAND, BRAKES COMPONENTS, CLUTCH MASTER CYLINDER, BRAKE MASTER CYLINDER, BUCKET SEATS MINT CONDITION, STEERING WRECK WITHOUT RACK ENDS, 19 INCH RIMS WITH TYRES HAS A STRATCHES FROM THE ACCIDENT, TAIL SHAFT, DIFF, TIEN REAR SHOCKERS WITH SPRINGS.
IF U WANT FAST RESPONSE I WOULD ADVISE YOU TO CALL ME AS I DONT OFTEN GET THE CHANCE TO GO ONLINE.
FOR ALL THE ITEMS ABOVE, JUST MAKE AN OFFER. ANY OFFERS MIGHT BE CONSIDERED. JUST WANNA GET RID OF THESE ITEMS. BUT PLEASE MAKE REALISTIC OFFERS
https://www.sau.com.au/forums/topic/296914-heap-of-r32-gtr-parts-for-sale-melb/
Price on front drive shaft??? or just the rhs inner cv joint???...delivered sydney......
front drive shafts 120 each...delivering im really not sure how do i go about doing that..if u can suggest anything im willing to send the pair at buyers cost
Hey mate i'm 3 sensors.
The first one is the out side temp sensor ( located near the aircon fan )
The second is inside temp sensor located in the center console near the cig lighter.
The third is the sunload sensor which is located in the dash passenger side top near the windscreen.
How much for these sensors.
Oh and can you confirm if your aircon was working
ahha nothing..i just dont know what they go for...i assumed it was much more as the r33 gtst was around 1k
r33 gtst ones can handle more power. harder to come by as more everyone wants them... going rate for r32 gtr is around 5-600$
Hey mate
im after the rubber spacer that goes under the gtr wing on the outside drivers side.
Not the one that gets bolted down but the outside one.
Can pick up.
If you have it how much do you want?
Need it bad
Cheers mate
  • 7 months later...
Guest
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
