hey guys i need some help im looking at putting a t51r with a .91rear housing its for a wrx that is now 2.6 ltr. i thought i would come over here and ask the skyline boys as i dont have any experience with these tubos.
the current engine set up is
wet sleeved 2.6ltr block
mahle pistons
par 1500hp rods
acl race bearings
2.5 crank
o-ringed block and heads
copper head gaskets
14mm headstuds
ported heads
1mm o/s inlet and exsurst valves
brian crower springs
wade 300deg cams
extractors
indy blue injectors
2x044 pumps
half inch fuel lines
ect list goes on
fuel - e85
the curent turbo i have is a gt35/66r it has 66mm front wheel, .80 front cover and a 1.06 rear housing and this turbo is to small and is on full boost just after 4000rpm but the the turbo has now spun the blade on the sharft and stuffed the front blade bent the sharft and stuffed the front bearing in it. and its going to cost 1200 to fix it, the turbo has now even done 200kms
so i was looking at a garrett t51r with a .91 rear housing do you guys think this will be to laggy on my set up ? im not to worred if it is abit because im running a nitrous kit as well
and i forgot to mention it has a built auto in it now with a 4,200 stall coverter
your help would be appreciated alot.
cheers
Edited by Lee586
https://www.sau.com.au/forums/topic/297324-turbo-help-t51r/
From the research etc. that we have done and advice given by people in the industry, the 0.91 rear will be laggier than the 1.01 or 1.05 rear due to it's TV (T6) flange which causes a huge pressure drop before entering the turbine. You are better off with the 1.01 rear that has a T4 flange. Considering there are none available or none have been sold in Australia, your options would be to buy it from the states or get the TA (1.05 A/R) rear milled to the T4 bolt pattern as they are only a mm or so different in their bolt pattern.
I would expect to see 1 bar of boost on the 1.01 rear at approx 5000rpm on a built EJ @ 2.6L.
And where did you get a GT3566R? Never heard of or seen one. I think you are probably referring to a GT3582R. Garrett don't make a compressor with an exducer of 66mm. that would be almost like taking the compressor off the GT3582 and putting one on from a GT2871....but smaller
https://www.sau.com.au/forums/topic/297324-turbo-help-t51r/#findComment-4950550
thanks for your help the t51r i was going to buy from turbologic he said it was a t4 flage witht he .91 rear so im not sure, the 66r i have was custom built by gcg it uses the same shafts and rear blade as the 35r but the front wheel is 66mm and has a .80 front cover with a 1.06 t3 rear housing
when looking for turbos it gets compacated the guy said he can only get the t51r in a .91 and a 1.05 rear housing with a t4 flange
https://www.sau.com.au/forums/topic/297324-turbo-help-t51r/#findComment-4950574
No, the GT51R comes in a 0.91 T6 (TV Flange) 1.01 T4 or 1.05 TA Flange. It also comes in others but not sure on those. I could find out if you really wanted the info on the bigger sizes.
The GCG turbo you are talking about is probably a T04Z compressor on the GT35R core. Very inefficient.
And Garrett would call it a GT3584R because it's the exducer that determines the last two digits. GCG like to be backwards.
https://www.sau.com.au/forums/topic/297324-turbo-help-t51r/#findComment-4950596
yeah they recon it was a to4z equverlent but it was really inerficent like you said, the turbo it a complete pieace of shit in my opinion.
what other turbos would you recomend for me as soming that might get decent boost around 4,800-5000.
i was also looking at the turbonetics gtk1000 it has a 76front blade 68rear blade with a .96 t4 rear housing
https://www.sau.com.au/forums/topic/297324-turbo-help-t51r/#findComment-4950615
How much hp are you chasing is probably the more appropriate question?
If you want 600-700hp at the wheels then pick a GT3788 or GT4088. You should see 1 bar at 3800-4000 on the 37 and about 4200-4500 on the 40. If you want 700-800hp then you will need minimum GT42 or above. Things start to get complicated after that and a lot of questions need to be asked.
https://www.sau.com.au/forums/topic/297324-turbo-help-t51r/#findComment-4950627
the auto draged about 50kw off at the wheels but i want about 400kw@wheels with the auto, and need somthing effecent enough to run 35psi
then will put a 150hp shot of nitrous ontop of that so there is a big chance it could go 500kw
we made 411rwkw with a cheap GT40 (v band rear 1.0) ($1300) through an auto on a1jz (2.5litre) at 22psi.
https://www.sau.com.au/forums/topic/297324-turbo-help-t51r/#findComment-4951896
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
