sold my 32 and no longer building a motor so these are now of no use
Sard 800cc twin spray injectors suit RB26 brand new in boxes $850
ORC quad plate clutch 1000ks old but doesnt have release bearing carrier but they can be bought as a spare part, suit push RB boxes $2500
RB26 crank brand new in box from nissan R34 model *only ones they sell now* so it's long nose $1050
ATI 600hp harmonic balancer suit R33/R34 brand new $700
Spool RB26 forged H beam rods with arp2000 studs brand new $650
RB26 cam and cam gear cover's, NO valley cover. cam covers fitted with Mines baffles and come with a ltd edition nismo cap, silver in colour but suit respray there pretty scratched up $450
located in Perh W.A, postage will be at your cost
please PM or call/msg 0411 811 231
Adam
Hey have u got any specs for the sards ie. Lag times and pics please
these are the 'kermit' sards, twin spray fit std rail or 11.5mm aftermarket rails. lag time 1.10msec
same as this
http://www.rhdjapan.com/home/products/prod...tr_product=SARD 800cc Injectorℑ=
engine covers sold
I've got a pair of defi gauges i wont be needing anymore for sale too
Oil pressure and oil temp in amber, with control unit. these were removed out of a wreck, due to the sender wires being taped into the custom engine loom the car had we had to cut the wires to remove them. any auto electrician or car audio shop would have no problems reconnecting them.
$400 for the lot not seperating.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
