Listed here is a couple of items that I dont need anymore as I have changed direction with my motor buildfor my 32GTR . All of these parts had been fitted and balanced to my motor but never actually turned over (my workshop can vouch for this). The parts have since been removed and cleaned.
Willing to accept reasonable offers, ono's, and FYI's as i would like this stuff gone asap. Any other queries, don't hesitate to send me a msg. I am located on the northside of Brisbane and will ship all items at buyers expense. Pick up is welcome also.
- Tomei Pro Cam Camshafts In & Ex, 270o 10.80mm lift $800
- R33 GTR Crank. Has been cyro treated for added strength, some small balance marks as shown in the pics. $850
- CP 86mm pistons $1100
- Tomei H Beam Conrods inc ACL race bearings $1300
- RB26 intake plenum $150
- RB26 throttle bodies $150
- N1 oil pump $250
- Greddy timing belt $125
Pics to come later today/tonight
Cheers..
https://www.sau.com.au/forums/topic/298466-rb26-performance-aftermarket-parts/
Some more info from some of the questions i have recieved.
- My mistake, the pistons are 86.5mm
- Some head work will be required to fit the swing on the camshafts
Cams, Pistons and Crank still available. Willing to drop the price on this stuff as i want it gone. Make me an offer as the other people have and got a good deal :P
Offers, criticism, anything?
Also, am after a forged box or gearset, and big brake kit so interesed in swaps too
Edited by dahandfull
PRICE DROP
- Tomei Pro Cam Camshafts In & Ex, 270o 10.80mm lift $700ono
- R33 GTR Crank. Has been cyro treated for added strength, some small balance marks as shown in the pics. $800ono
- CP 86.5mm pistons inc pins $900ono
- OS Giken twin plate clutch has been fully reconditioned by Direct Clutch in Albion. $600
(more info shortly ie: push/pull as i will pick it up from GT Auto in the New Year)
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
