Hi All,
I have a pair of HKS 2530s for sale. They've been on my car since approximately 2005. They are pretty stuffed. It appears the previous owner of my car neglected to change the air filters the whole time he had it. They still work, one is pretty noisy on shut off, the other is okay but you'd have to rebuild them of course. I'll get some pics up when I have access to my facebook tonight.
The thing is I have no idea what they are worth, so I can't post them in the for sale section... So I guess offers? And any advice on what they are worth would be appreciated.
Cheers,
Matt
https://www.sau.com.au/forums/topic/299213-hks2530s-gt-r/
Just FYI I think you should be able to get somewhere from 2000-2500 for them depending on age/condition. I recently bought a single one for an RB20/25 for $1600 but it was very new and in pretty much new condition. If I ever had an RB26 they would be the first turbo I go for, awesome response and peak power.
https://www.sau.com.au/forums/topic/299213-hks2530s-gt-r/#findComment-4987583
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
