- Z32 AFM with plug SOLD
- Yellow Jackets coil packs suit r33 series 2 SOLD
- BLITZ Sbc ID3 SPEC-S Electronic Boost Controller SOLD
- Rda slotted rotors & QFM-k750 hight temp pads SOLD
still waiting for my phone call about the cooler champ .........
0433044264 if u have lost it ....
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
