Have a few xbox 360 games for sale if anybody is interested.
Call of Duty Modern Warfare 2 Prestige Edition includes Nightvision goggles, head to put the goggles on, and the hardened edition of the game, package is still unopened. Asking $300
Prototype still sealed $60
Guitar Hero 3 $20
Guitar Hero World Tour $40
Guitar Hero 5 $50
Fear $10
Fear Files $15
Fear 2 $30
Lego Star Wars Complete Saga $20
Lego Indiana Jones $10
Halo ODST $65
Infinite Undiscovery $30
The Last remnant $30
Juiced 2 $15
Assassin's Creed $10
Call of Duty 4 Modern Warfare $40
Call of Duty World at War $40
Ninety Nine Nights $10
Devil May Cry 4 $25
Rainbow Six Vegas 2 $15
Samurai Warriors 2 Empires $15
Dynasty Warriors Gundam 2 $45
Located in Brisbane. Pm or reply in thread for interest.
https://www.sau.com.au/forums/topic/300063-xbox-360-games/
  • 3 weeks later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
