hey guys
i hv n going through cold start problem with my skyline gtt..the car doesnt want to start when the engine is dead cold..its got an aftermarket microtech ecu...and i must say cold start problem appeared after the ecu was installed..wht do u guys think abt tht..is tht a wiring problem?..or battery..?
https://www.sau.com.au/forums/topic/300760-cold-start-problem/
hey guys
Engines require more fuel when cold, and even more again while cranking. If the problem appeared after installing the microtech, take it back to the installer/tuner and get them to fix it.
Or go back the the standard ECU and all problems will be fixed.
yeah it's pretty much certainly going to be due to the tune on the ecu.
yea mate..my mechanic said..microtech computer is made for racing purpose..as they r trying to use it in my car for street purpose..and it doesnt hv tht feature..so cold start problem will remain there...wht do u think abt tht?..in dead-cold situation they asked me press the accelerator paddle while cranking..is it safe?..ur opinions will be appreciated..thnx guys
i dnt thnk it wnt cse ny prblms by hldn dwn the acclrtr whle strtng the engne
if ur mchnc cn tne the engn prprly u wnt hv any prblms strtng it cld, plnty of ppl runng microtechs fne bt it csts lts to hv it dne rght.
fark... sms speak on a forum is tough to type and a prick to read... that was a serious reply though.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
