A friend of mine has just returned from holiday's to find his skyline missing.
If anyone has seen/heard anything at all, please send me a pm and let me know asap.
Plates: [YDNYPSI]
Still had the same blue graphic's on the side and a very large 'Greddy' one going down the side.
Very difficult to miss if you see it out driving. Unsure at this stage when the car actually was taken, but if you seen it within the last 7 day's please pm general location and time.
https://www.sau.com.au/forums/topic/301378-stolenr33/
Why would you steal that?
f**k i hope they get it back.
id steal it for the cooler piping and dump pipe
seriously tho, no chance theyd drive that around- parted or will be found in perfect condition somewhere way down south like the last few recently
Edited by Char
https://www.sau.com.au/forums/topic/301378-stolenr33/#findComment-5004231
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
