Up for grabs is my
1989 A31 nissan cefiro
-LIGHT BLUE(few dints+scratches hear and there and rhr gaurd has scrape but all in all very clean
-RB20E
-Auto
-Near new Exhaust system(standard)
-4 rwc condition tyres on CA s13 rims
-HID look parkers
-Near new alternator
Ect....
i recently purchased this as my dailey but im going to c if theres any interest as i may go back to bikes
it has reg till june-july this year and has been recently serviced and start and runs immac
I also have the foolowing which will come as part of the deal
-RB20det complete motor with coils,turbo ect ready to bolt in with a loom(not included)
-ASi 52mm ALOY twincore radiator(brand new $235+post 2 weeks ago)
-RB20det MANUAL ECU(standard no remap or chip)
-SONIC 12" thermo fan kit(brand new just oped package)
I will sell the car and the extra parts for
$5000 ono no retarded low ballers as this is a genuinely cheap kitup
i will take photos tommoz in day
pm me offers or post it up
located in Melbourne
will trade for registrable MOTARD or ROADBIKE
Edited by green1via
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
