any tips on the rb30
Sell it :)
All jokes aside, it really depends on what sort of set up your chasing, if you want it to remain legal/street registered or a trailer queen? Whats your budget, auto/manual, are you only wanting to do engine work or rest of drive train etc???
Give us some more details and we can offer some advice :)
Sell it :D
Give us some more details and we can offer some advice :P
i would like a rb30 turbo setup not sure to go rb25 head tho street legal registered budget is 6000+ i have a mf5 5speed and just looking to do the engine at the moment
Well would pay to look around for a blown rb25det with harness
Then bolt it together then get a plenum, high mount turbo about a gt3540 size, power fc, 550cc injectors and you should get about 270-280rwkws or so
thank you mate
Or not, I mean you could buy all the same stuff, good standalone ecu, or Nistune for the stock ECU, and make the same power with the original head for the price of a couple of psi more boost.
$6k won't get you an RB25 head swap and good support parts, but you might squeak it in with the SOHC head.
well im doin up a a rb30 and just after any tips at the moment its my first time
Is it an N/A VL? I'm assuming it is.
Your gearbox will limmit you to around 200 rwkw... after that it will break. (If it's a VL turbo box.... 250 rwkw and not much more.)
Dont bother with a twin cam swap...
Basic Recipe:
- Basic re-build, with turbo pistons, good bearings and good oil pump. Clean the head up and use a new timing belt
- New injectors, z32 afm, upgraded ignition coil, nistune and a VL turbo computer.
- Front mount intercooler, VL turbo exhaust manifold, T3 flanged- internal wastegate turbo of choice and plumbing.
- Ancillaries... clutch, consumables, hoses, pipe work, exhaust, intake, plugs etc...
Tune it and go...
BUT- Dont forget to upgrade your brakes, suspension and brain.
If you want a quick streeter, keep it simple. if you want to go fast... how fast do you want to spend???
cheap- reliable- fast ... pick 2.
If this is your first build up... be warned, cars and speed is addictive!
Cheers
Justin
^^ do not take notice of this dead shit ^^
G'day mate.
Sorry to but in, but i think i have a solution for you.
what i have is easy, complete,turbo'd and best of all ready to drop straight in.!
INTERESTED??
CALL/TXT ME 0417 529 889
plus i have a pallett load of spares to go with it...!
its ur's for the beggin mate.. dont let it slip away..
:D
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
