Hey everyone.
I have some r34 calipers (the gold ones) fronts only, some slotted disc in 324mm diameter. and Also PMU pads in the brembo's.
The pads and calipers have about 3000km of highway use which was a trip from brissie to townsville and back.
Both discs and sets of pads are fine with PLENTY of life still left in them.
The calipers are in a good condition with a minor scratch on the inside of 1 caliper.
I am selling these due to having changed to an AP racing setup now and no longer need these.
The only picture I have is of when they were on the car as the camera has since broken, if you want more pics let me know and I can see how the phone camera goes.
Price: $2000
Location: Brisbane (would prefer local pick up buyer but can freight at buyers expense)
Contact number: 0421 933 614
Email: [email protected]
Thanks,
Nick.
https://www.sau.com.au/forums/topic/303758-r34-brembo-calipers-and-discs/
Good question Jason..?? not sure..
Obviously the project MU pads and rotors would be worth something as well though seeing as they are basically brand new.
But if anyone wants to make an offer I could consider.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
