Item: 1997 Nissan Stagea Rs4
Website: Here (will be up on a couple of others)
Item Condition: Immaculate
Reason for Selling: Want a 200sx or a r32 or something RWD
Extra Info: Rb25det series 2 engine,Awd(gtr running gear),1.2mm (i think) cometic metal head gasket, 124000 klms,Privacy glass, r33 wheels, pod filter, tv screen (touchscreen),Tow ball, stacker,Climate control, auto, goes very well! Also has dual sunroofs that is quite rare and the original jap log books
We have also recently done a MAJOR service on the car and replaced; Water pump, timing belt, etc and had the head of and did the metal headgasket and all the neccessary work to go with it (i.e acid clean the head) etc)
Pm me here with offers for swaps or call or text me on 0407626786
https://www.sau.com.au/forums/topic/303849-nissan-stagea-rs4/
  • 3 weeks later...
  • 1 month later...
interested in non turbo 4 door r34 skyline? located on gold coast. very minor body work needed. Can be repaired very cheaply as my father is a panel beater. PM if interested. After a stagea due to new addition to the family
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
