hey guys well been having this problem for a while really have no ide awhat it could be i have changed the coilpacks and plugs still have the same issue any idea what it could be? it almost sounds like what happens when u hit the speed limiter soo im really confused and is making me really angry also the car has a miss when idleing and is worse when its hot
any ideas?
Injector plugs dodgy?
Narrow it down to which cylinder by unplugging one injector at a time until the misfire doesn't change
yeh thinkin i might have to do that aye but if i do that and find out whihc one it is how can i fix it?
Elimination.
Say it's cyl #2
Swap the coil pack between #1 and #2 and see if the fault follows the coil pack. New coils can be faulty too.
If it doesn't, remove coil number 2 from its mounted position, put in any spark plug, earth the body with a jumper lead, disconnect injector number 2 (so you dont foul the existing plug) and start the motor. Identify if you have spark.
If you do have spark, the injector could be faulty or the wiring to the injector could be faulty.
If you do have spark, and the injector is firing, check the compression of the cylinder when the engine is cold and hot.
Narrow the fault down and come back with your results.
does it have any problem when cold? How many Km's has the car done? Like it is hitting the limiter? My car had a similar problem at one point around 40 000km mark. When accelerating hard it would be like it hit limiter and the tacho would sometimes jump around like crazy even at 3000rpm, it would also miss and carry on when hot, sometimes when cold anyway after about a month of trying to figure it out a light came on the dash i took it into work and got it put on the nissan consult, i had a code for the O2 senor (which has main effect when car is hot) so i replaced it and problem fixed. In short your problem maybe the O2 sensor starting to fail? maybe?? just a suggestion hope it helps
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
