New Innovate Motorsport wideband O2 sensor Kit
Here I have a brand New DB-Blue Gauge / LC-1 Kit - P/N: 3795 - #3795
It's an unwanted Christmas gift. It's never been fitted to the car & was only recently opened to check everything was included & for a photo. As you can see it's all there & I'll even throw in a gauge holder.
I've only had it a couple of weeks so it still has plenty time left under warranty.
Innovates Recommended Retail Price is $229 + Standard Postage of $92.25 = $321.25 USD = around $360 AUD including postage if you pay with Paypal.
Check out the link below for more info:
http://www.innovatemotorsports.com/products/db.php
$275 posted Express or Registered.
$260 if you come to Bondi & pick it up.
[email protected]
0403 702 449
Edited by Sydneyactionman
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
