Silver 93' R33 Skyline GTS-t M-Spec. Rego: ACT YDO-32P
This car is a TRUE head turner and will not disappoint! Features on the car include:
Engine:
Full 3" Turbo back exhaust (Titanium from cat back!)
Nismo FMIC
HKS Super Sequential BOV
Blitz Airpod
Oil Catch Can
JJR Coilpacks
Chipped ECU
Suspension:
HSD type HR Coilovers
Front Sturt brace
Lower Control Arms
Tie Rod Ends
Whiteline Sway Bars
All Bushes Upgraded
HICAS Lockout Bar
Brakes:
DBA 4000 Slotted Rotors
Bendix Ultimate Pads
Stainless Steel Braided Brake Lines
Rotors repainted red
Motul RBF 600 Fluid
Custom Front Brake Air Ducting
Drivetrain:
Kaaz 1.5 way Mech LSD
JJR Single Plate Ceramic Button Clutch
Wheels:
17" Blitz R Racing Wheels (Sprayed black)
or
17" Rays Volk GT-C series 1
Exterior:
Nismo Front Bar
400R Side Skirts
Adjustable GTR rear wing
Full Nismo decals
Nismo Clear Side Indicators
Interior:
Bride Bucket Racing Seats
Custom Rear Parcel Shelf
Panasonic Head Unit
Pioneer 4-way speakers
A-Pillar Mounted Boost Gauge
Oil Temp Gauge
White Dials
Momo Gear Knob
Apexi Turbo Timer
Dash Painted Silver
The car has always been garaged and service every 5000 KM's and currently has done 140,000 KM's. It was last dyno'd with 209rwKw. This car has and will put GTR's, STi's and EVO's to shame around Wakefield Park. All the suspension components are adjustable. The car is unbelieveably reliable and has never had any major problems while I've owned it. Next owner will not be disappointed...
I have a 2nd set of wheels which can be included in the sale/trade for a little extra. The Blitz wheels are currently on the car and are the ones pictured however they have now been sprayed black, giving the car a true Nismo look!
Looking for $16,500 or a straight swap for manual Bugeye WRX or onwards.
Contact Luke on 0438 481 354 or email at [email protected] or PM here...
post-17810-1263874642_thumb.jpgpost-17810-1263874657_thumb.jpg[attachmen
t=266373:me5.jpg]
I can confirm that this car is SUPER reliable and very fast around a track... I have driven this car multiple times and found that it has unbelievable amounts of grip and control.
Sensible mods done, strong motor and drive train, a well cared for car... This car has done low 1.09 laps of Wakefield Park with only 209rwkw.
Its a shame to see it go Luke :P
**BTW Free Bump**
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
