was a great night though till the boys in blue decided to come out in fource good to see that 99% of the cars were qaulity
How did the cops know where you were heading? I saw the one cop cruising around the 2nd meet but that was it.
not to shore but they had the chopper on us for a wile shortly after 2nd meet
Was that down Mundaring Wier rd? I read anti-laggers boasting they can do that in 10 mins. It's 24 km long!
the chopper showed up in pinjarra not to shore how long he was on us for yeah i seen a few reacon u can do it in 10min but coming from the other diretion prob could in the right car. mine would slide round to much to do it in that time
Ha ha I was doing it the other night in the dark and reckon it took me twice that long, but a) I don't know it, and b) it's a mega dangerous road being narrow, trees, blind corners, negative camber, Roos, plus ehem *cough* I was being mindful of the speed limit. :banana:
Ha ha I was doing it the other night in the dark and reckon it took me twice that long, but a) I don't know it, and b) it's a mega dangerous road being narrow, trees, blind corners, negative camber, Roos, plus ehem *cough* I was being mindful of the speed limit. ;)
yea its fun isnt it :) u heading out fri night on the antilag cruze??? im still waiting on the maps to be posted but am keen will be the last cruze i can go on 4 a wile :banana: damm work!!!
yea its fun isnt it :) u heading out fri night on the antilag cruze??? im still waiting on the maps to be posted but am keen will be the last cruze i can go on 4 a wile :) damm work!!!
Gotta work I am afraid. :P
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
