so my top tank is leaking so i pulled it out and dropped it into a radiator place for them to have a look at it
the core was really thin so i'm looking at the justjap rads they have
they have a triple core 40mm one: http://justjap.com/store/product.php?produ...=300&page=1
and a twin core 60mm one: http://justjap.com/store/product.php?produ...=300&page=1
which would cool better? they both say that they retain the factory shroud but is triple core better than twin or is thicker better than thinner?
just incase your wondering, its an rs4s = manuel
https://www.sau.com.au/forums/topic/306478-rads/
i would go the 60 if you can fit it in . holds more water =win .
i have a rs four s and i put this one in
http://www.trademe.co.nz/Trade-Me-Motors/C...n-268244021.htm
the only problem is the mounting pins are too taf back for the factory mounts . if you look at the radiator from the top you will notice the pins are along the centre line . they need to be offset towards the front . it will fit but its not ideal
https://www.sau.com.au/forums/topic/306478-rads/#findComment-5066236
When it comes to radiators, the more coolant you can hold in the system the better. I have a 52mm alloy radiator and its been one of the best decisions I've made. A week of 40+ degree days didn't see the temp needle budge at all.
:D
https://www.sau.com.au/forums/topic/306478-rads/#findComment-5066511
just take the car to your local ultratune and get them to turn it into a custom purple R32
Is this still going?
Pipster, others are on the right track here, the 60mm core will hold more liquid= win. Also the 3 core 40mm may actually be less efficient than stock due to the extra core and the extra restriction it presents.
60mm core if you have the room.
https://www.sau.com.au/forums/topic/306478-rads/#findComment-5068160
I've got same issue with my 52mm radiator - mounts need to be offset.
Go The 40mm pipster - less restriction to airflow & Shroud should fit too.
Mine actually ran cooler (1'c) with 40mm out of my R32.
https://www.sau.com.au/forums/topic/306478-rads/#findComment-5068656
for the 300 bucks it cost me im in love with it . i am on hiloday atm and on the way here was doing some spirited driving(well going the speed limit with the boat on the back over the lewis pass ) about 25 degrees outside . pulled over at toilets and grabbed the bottom rad hose and it was barely luke warm. like slightly colder tham my hand . i have the fan but no shroud atm as i broke it ages ago
https://www.sau.com.au/forums/topic/306478-rads/#findComment-5068762
I just fitted alloy L bracket from bunnings ($6 & 50mm by 20mm) between top mounts to cover fan.
Didnt even bother NSW or QLD RWC inspectors!
Might want a HOT sticker on top of Radiator as bit warmer than plastic tank!
https://www.sau.com.au/forums/topic/306478-rads/#findComment-5068780
cool, thanks guys
sorry for my lack of input on the subject but i was on holidays for a few days
just to check, is it deffinately an r33 rad that i need? or will a 34 rad fit? i'm leaning towards the 40mm rad cos i know there will be no issues with fitment and i dont wanna have to put a thermo fan on it
https://www.sau.com.au/forums/topic/306478-rads/#findComment-5072869
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
