nissan silvia s13 . rb20 . manual . 130xxx on the clock (original) . motor 90xxx hardly drivin.
silver with gray bottom . elec sunroof . elec windows.
MODS:
- xs power himount manifould
- 80mm throttle body
- 40mm external wastegate
- twin auto thermos
- alloy radiiator
- surge tank huge fuel pump
- 600cc injectors
- sway bars
- hsd coilovers with camber tops
- 30mm spacers
- blitz electric boost
- d1 steering wheel
- black drift teks . 17x8.5 front . 17x9 rears
- air flow mmeter
- trust air filter
- garret 25/80 turbo custom built
- front mount
- 3 inch xhaust
- ajustable cam gears
- shimmed diff
- xtreme heavy duty clutch
heaps moreeeee !!! $ 9500 ono ....
ph: 0420241646 message me for more info .. will send pics ..
got plenty of recipts
car makes 244 rwkw on 14 pounds
on 17 pounds makes 255. capable to make plenty moree!!! (got dyno papers )
https://www.sau.com.au/forums/topic/306689-s13-rb20-250-at-the-rears-sa/
