another daily driver for sale
My sister's Black Holden/Opelized Vectra up for sale
upgrading to Turbo JDM cars now. since she is getting
her full license soon
Model: Holden Vectra JS2 (Opelized)
Kms: 132XXX KMS
Price: $9,000 neg
Trans: Auto
Mods:
DeBadged all around
Irmscher grill
Irmscher side logos
Irmscher tail lights
Customize Exchaust 2 1/2" alll the way
King springs sport low
Pedders sport suspension
P&W chrome 18" wheels
JBL sound system
2 amps 614Watts 4channel each
2 12" Sub with custom JBL box with led light and clear glass (1500 Watts each)
Pioneer Deck
Contact details: Raffy 0425-202-407
By vrr55h at 2010-02-05
PM me for more photos
https://www.sau.com.au/forums/topic/307072-opelized-vectra/
Your on opelaus and brought your skyline to the mac pass Opel cruise ages ago right??
(i used to have the silver vert with the mesh wheels then)
Yeh thats me this opel is up for sale now :thumbsup:
DId you go to last cruise went to mac pass?
Im the one whos driving the yellow evo with the evo boys :blush:
https://www.sau.com.au/forums/topic/307072-opelized-vectra/#findComment-5087915
Yeh thats me this opel is up for sale now :)
Im the one whos driving the yellow evo with the evo boys :P
Yeap, you bought an evo?? that yellow evo was niaceeee!
This is mine:
http://www.skylinesaustralia.com/forums/post-a270093-
BTW: This car is sick!, i hope it goes to an opelaus member so they keep the opelness going.
https://www.sau.com.au/forums/topic/307072-opelized-vectra/#findComment-5089265
This is mine:
Thanks man yeh really love some euro cars actually me and my partner are keeping my accord 05 Euro and the Evo :thumbsup:
yeh hopefully someone pickup this lovely car really rare in Aust
https://www.sau.com.au/forums/topic/307072-opelized-vectra/#findComment-5089598
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
