hi
im selling a set of wheels. they are 19" chrome Vault rims. i am selling due to they came with the new car i brought but i dont want them so i am selling. they are almost brand new, cost $2200 all 4 brand new, no marks on, them all clean and in good nick.they just same off a nissan skyline r33 gts. they are 4 stud rims, the wheel tread is kumho, size of them are 235/35 ZR19, come with a cap with a lock key.
item:19" chrome vault rims x4
price:$1800 ono, no refunds
post: pik up onli
piks below.......
https://www.sau.com.au/forums/topic/307506-19-chrome-rims/
  • 2 months later...
