For sale is my 2003 Yamaha R1. Fuel injected, has a Yoshimura system and oggy nobs. It is in immaculate condition as you can see in the pics. Serveced every 5000km. odomitor reading 52xxx. Rego wb443. has approximately 22 months warranty left.
Welcome for inspections, I'm located on the goldcoast.
$6,800
Ryan 0438504324
https://www.sau.com.au/forums/topic/307573-yamaha-r1/
