Ill take em pm me info on payment
SOMEONE WAS GOING TO PICK THEM UP ON FRIDAY BUT COULD NOT MAKE IT AND HAS SAID THAT IT WILL BE TODAY , BUT IF THEY DONT SHOW TODAY THEN YOU CAN HAVE THEM , CHEERS Aaron.
I'm interested in them if they're still for sale
THEY ARE BRAND NEW ! still for sale $200 plus post , they are $300 plus post from just jap so no offers !
hey man got 32gtr whats your best price pick up..
$200 pick up from chatswood or gosford , thats 100 cheaper than you will get for brand new covers , i would rather sell at a loss than have them sit here ! Cheers
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
