2K??? Wow... I was speaking with a friend last night who said all you have to do to change your insured value with JustCar is phone them up and explain to them what you have got done and why your car is worth that much. Adds a bit to your premium of course, but apparently that's all it takes
Went down to $1.5k this year, due to no claims being made (no traffic fines either! :))
I think I might take a gamble & use their $1100 excess adjust to bring down my rate down to $900ish but excess will be >$3k ouch...
Edited by Mayuri Krab
i changed my car (sold old bought new) and upped the value at the same time with just car and they didnt charge me a cent. got the next bill and it was still the same amount as the older cheaper car. only 3rd f+t but still nice not to be charged extra
Their values really don't change which I find quite annoying as I plan on downgrading.
30k car - 1.5k a year
10k car - 1.5k a year
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
