Item Summary: silver 1996 R33 GTst with minor mods
Reading: 98500km
Condition: Used
Reason for Selling: upgrading 2 a new toy : )
Asking Price: $14500
Delivery Methods: PickUp
Contact Info: 0431 564929 (luke)
Engine/Drivetrain
Pedders lowered springs (40mm)
Trust intercooler kit
Trust Type-s blow off
HKS SuperDragger cat back exhaust 3.5"
jjr 3" ss split dump pipe/front pipe
Exedy Heavy duty single plate clutch
Rda slotted front rotors
3" ss intake pipe w/ ss pod filter
R34 turbo
New ngk platnium plugs
Candy orange rockercovers
Polished n detailed everything
Interior
Almost perfect condition sr3 recaro seats in red
Red leather gearboot n handbreak boot
Trust gear knob
Exterior
Standard s2 apart from gtr wing and s2 4 door grill
19x8.5, 19x9.5 tenzo-r gt-05 wheels black w/ chrome lip
Sound System
Alpine Type-s 6.5" splits front
Alpine Type-s 6.5" 2-way back
2x Alpine v power Amps
2x 12" Alpine Type-S Subs
Alpine top of the range fold out
touch screen dvd plater
Other
Full Mongoose alarm system
also comes with new top secret front bar and copy greddy plenum
Awesome car, very quick n reliable, has never had any problems. car needs 2 go make me an offer comes with 10 months rego
I will make u offer 7k
no need the rego
let me know
cash take it from u this saturday
hahaha. why so high? why not just offer him a pack of chips and a can of coke? small chips. not those big expensive ones!
hey mate nah im sweet with an inspection, havent done 100k servise yet but previous owner changed the timing belt and i service it every 5000 kms.
nah dont smoke and its never been tuned, still running standard boost.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
