WRECKING 1995 R33 S1 GTST MANUAL, MAROON
LEFTOVER PARTS FROM A WRECK
x4 doors 4dr $50 each complete
x6 window regs and motors $50 each
front and rear seats $100 set
dash complete $150
cluster auto $100
x8 seat belts $50 each
bonnet silver(small bend in rh corner easy fix) FREE
bonnet maroon perfect $100
headlights $100 each
rh 4 door tailight $50
passenger side door 2dr $100 each
grill $50
gaurds x4 $50 each
side indicators x4 $50 pair
front indicators x4 $50 pair
passenger window switch $50
rear window switches $30 each
door windows $50 each
mirrors x4 $50 each
rear floor mat 1 piece FREE
overflow bottle FREE
washer bottle FREE
ac condenser $50
power steering rack $100
front k frame $150
rear k frame x2 $150
front castor rods $50 each
control arms $50 each
struts and springs $200 pair
front calipers $200
front and rear discs $40 pair
front and rear hubs $100 each
rear calipers $150 pair
x2 auto tailshafts $50 each
manual tailshaft $150
fuel tank $100
drive shafts $70 each
diff manual $200
stock afm pink $100
climate control box $50
boot lid $100
tail lights $100 each
series 1 used coilpacks $100 set
series 2 used coilpacks $100 set
series 1 new jjr coilpacks $500 set
MAKE AN OFFER I NEED THIS STUFF GONE!!
PLEASE PM, SMS OR CALL 0424144636 LOCATED IN EPPING MELB
Edited by myr33wpn
  • Replies 40
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
