So, long story short - car has been scratched because of a garage issue. Wont go into it as im still upset..
anyway, the paint is gone, and the scratch is too long and wide for that stupid pen. Will have to get it fixed eventually, but is there any stuff i can buy like those magic pens except easier to apply with a paint brush? Will need to protect it from rust.
https://www.sau.com.au/forums/topic/309319-deep-scratch/
They're double sided pens with my exact paint color code. so for stone chips etc you just apply with the pen and on the other side is a clear coating to seal it. Its only good for little chips we all get on our front bumper really.
Ogz, im in brisbane but looked up the touchupguys here and they seem legit. Will take before and after pics for anyone whose interested in brisbane.
https://www.sau.com.au/forums/topic/309319-deep-scratch/#findComment-5101269
Anybody out there that wants a job done as good as a panel shop but a hell of alot cheaper try these guys, And not just for scratches they will even fix small dents and few other mishaps , alloy wheels etc. All in the comfort of your drive way.
http://www.thesmartguys.com.au/
Not a franchise so go the National Pricing.
https://www.sau.com.au/forums/topic/309319-deep-scratch/#findComment-5102127
there is now new restrictions in terms of shipping this from overseas.. Due to its liquid substance majority of the dealers there do not choose to sell this to overseas customers, however you can always try. I tried before and failed, so i just went to local nissan dealer parts and got mine for $15.00.
https://www.sau.com.au/forums/topic/309319-deep-scratch/#findComment-5111969
went to nissan today they have it, its a nail polish sorta thing and you apparantly apply it, the guy there didnt know anything about it, so im wondering do you need to prep the car or do anything before applying it? also does it blend with the colour and surrounding or would it stick out like a sore thumb?
https://www.sau.com.au/forums/topic/309319-deep-scratch/#findComment-5112600
Ive used the same from g35parts, IMHO they are ok for very small areas, anything other than that you`re better off getting it done either at a bodyshop (dependant on extent of damage) or by some touch up franchise (do your research first as Ive seen some appalling work)
My bodyshop does stuff like full bumper respray etc and I use chipsaway (local franchise) for any light scratching/stone chips elsewhere.
Good luck in getting your 350 sorted
S
https://www.sau.com.au/forums/topic/309319-deep-scratch/#findComment-5113380
Hey sai how much does it usually cost ya to do those scratches and stone chips?
S
https://www.sau.com.au/forums/topic/309319-deep-scratch/#findComment-5114134
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
