Silverstone Semi's S585 soft compund
set of four, size 235/45x17
never fitted retails aprox $1300
sell set of four $800
or pairs at $450
pm or ring 0403 071 294
Yes i know stick them in the F/S section, but most who motorsport will realise that these are a true semi, not some so called "race" type marketed tyre that we can all get for $136.75 or whatever.
looks like a good buy for anyone doing hillclimbs/superlap etc.
where did you get silverstone softs, and have you run on them? Are they wet only or OK for supersprint style use
Silverstones are supplied by Alan Stean- Distributor in QLD at Underwood, they are the S585 pattern so more suited to dry /intermediate use, they would be the ducks guts for supersprints etc.
I have run on this pattern/compound, but in a 15" version.
The harder compound version is used in Classic Adelaide/ Targa Tas etc.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
