Mate, that looks f*kn fun.. I think you liked it too with your laugh at the end :rofl:
Last left hander the big girl gets a lil slidey and taking the slight bend at speed gets the heart going then cross line @ 200 odd ks :)
The owner was saying the car was built by Mark berry ( Gibson motorsport fame ) so it sure has some good history.
MMMMM yea this was built by Advan Performance in NSW , but what would i know :down:
Edited by Dsturbd
I went to autoworx a few weeks after that dyno day and they were still talking about that run actually =D
Nice video, it's cool people are starting to put these up at the moment
We purchased a few of the cameras as we run 3 cars .. thats first time we tried them out .. GoPro is brand . $435 ea
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
