Nissan r32 Posted March 3, 2010 Share Posted March 3, 2010 All parts are out of a 1993 model R32 Skyline 2 door. Parts include: Drivers seat $50 Rear Seat $60 Rear centre seat belt $20 Window wiper motor $40 Air con pipe (firewall to compresser) $20 GTST Bonnet (Silver) $100 Drivers door (Black) with glass and power window motor $100 Boot Lid (Black) Slight repairable damage $30 Stock dump pipe (Turbo to cat) $30 Stock Cat $20 LSD Diff centre $180 Manual Tail shaft $100 Brake Booster $40 Rear Brake calipers + discs $60 the pair ® Rear quarter trim (Bottom half) $20 Scuff plates + Clips $30pair Pioneer detach face stereo 200w $20 Base 10" sub in box 500w $20 Indicater stalk + horn wire (Complete unit) $100 Boss kit $30 Front strut brace $30 Interior light $10 Rear view mirror $10 (L) Electric mirror (Black) $50 Door check straps both $20 All door lock rods + Clips (both doors) $20 Electric sunroof switch + Interior light $50 Centre dash tunnel surround $10 Passenger glove box door $20 Climate Control Unit $100 Nismo gear knob + handbrake lever both new in box (Never used) $50 Drivers side plastic guard liner $20 Space saver spare wheel $40 Timber plate to cover spare wheel $20 Stereo brackets + Compartment $20 Fuel Flap (Black) $40 Fuel Cap (Nissan) $10 Number plate lights + wiring and fuses $20 Lots of RB20det Engine parts: Motor only done 82000km: Crossover Pipe with BOV mount + gasket $50 Top + Bottom Radiator hoses, near new $30 Clutch Fan $60 Coil packs x6 $80 Coil pack plates + bolts (to hold coil packs in place) $40 Igniter $40 Pulley belts x 2 $20 Throttle body (Complete) $50 Inlet manifold $80 Stock turbo + Wastegate actuator $350 Stock turbo oil + Coolant lines $30 Crank Angle Sensor + Bolts $50 Stock front mount under bonnet piping (all) $60 Alternator (Gen Nissan) $60 Power Steering pump with bracket $100 Power steering reservoir $20 Century Battery, near new $50 Air flow to BOV Steel pipe $20 Engine mounts $50 each Harmonic Balancer $80 Fly wheel $60 Starter motor $80 RB20det Engine Block and head Complete $500 Good for someone who needs a bare block and head and can swap all there stuff over onto. E.G: If your RB20 is blown, heres a good motor for you, just need to swap all your stuff over. RB20det 5 speed Gearbox (No crunches, or noises) Very clean, smooth and quiet box $500 Im located in Ashfield (Sydney) Postage can be arranged at buyers expense PM or contact me on 0415126075 Cheers Sam Link to comment https://www.sau.com.au/forums/topic/310465-wrecked-r32-skyline-rb20det-parts/ Share on other sites More sharing options...
gttiwanna Posted March 3, 2010 Share Posted March 3, 2010 radiator? Link to comment https://www.sau.com.au/forums/topic/310465-wrecked-r32-skyline-rb20det-parts/#findComment-5114920 Share on other sites More sharing options...
Nissan r32 Posted March 3, 2010 Author Share Posted March 3, 2010 radiator? Sorry don't have radiator Link to comment https://www.sau.com.au/forums/topic/310465-wrecked-r32-skyline-rb20det-parts/#findComment-5115308 Share on other sites More sharing options...
Beacher1B0 Posted March 6, 2010 Share Posted March 6, 2010 Any mint sunroof parts kickin around? I need it all except glass, switch and motor. Thanks. Mike. Link to comment https://www.sau.com.au/forums/topic/310465-wrecked-r32-skyline-rb20det-parts/#findComment-5120442 Share on other sites More sharing options...
Yts Posted March 6, 2010 Share Posted March 6, 2010 have you got the tyre plackard? if so how much Link to comment https://www.sau.com.au/forums/topic/310465-wrecked-r32-skyline-rb20det-parts/#findComment-5120526 Share on other sites More sharing options...
Curmi Posted March 6, 2010 Share Posted March 6, 2010 pm sent Link to comment https://www.sau.com.au/forums/topic/310465-wrecked-r32-skyline-rb20det-parts/#findComment-5120537 Share on other sites More sharing options...
aussietroy Posted March 6, 2010 Share Posted March 6, 2010 pm sent Link to comment https://www.sau.com.au/forums/topic/310465-wrecked-r32-skyline-rb20det-parts/#findComment-5120541 Share on other sites More sharing options...
willL Posted March 6, 2010 Share Posted March 6, 2010 windscreen demister front dash vents? Link to comment https://www.sau.com.au/forums/topic/310465-wrecked-r32-skyline-rb20det-parts/#findComment-5120573 Share on other sites More sharing options...
apocalypse Posted March 7, 2010 Share Posted March 7, 2010 Hey bud i'm looking to buy ecu + wiring loom, airflow meter and maybe the coil packs and igniter. How much $$ and will you post to S.A? Link to comment https://www.sau.com.au/forums/topic/310465-wrecked-r32-skyline-rb20det-parts/#findComment-5120774 Share on other sites More sharing options...
Nissan r32 Posted March 7, 2010 Author Share Posted March 7, 2010 Any mint sunroof parts kickin around? I need it all except glass, switch and motor. Thanks. Mike. Hi Mike Sorry mate all I have for R32 Sunroofs is the switch unit with the interiour light. Let me know if you want it. Cheers Sam Link to comment https://www.sau.com.au/forums/topic/310465-wrecked-r32-skyline-rb20det-parts/#findComment-5121042 Share on other sites More sharing options...
Nissan r32 Posted March 7, 2010 Author Share Posted March 7, 2010 have you got the tyre plackard? if so how much Hi mate Sorry I don't have the tyre plackard. I think you can get them on ebay bro Cheers Sam Link to comment https://www.sau.com.au/forums/topic/310465-wrecked-r32-skyline-rb20det-parts/#findComment-5121044 Share on other sites More sharing options...
Nissan r32 Posted March 7, 2010 Author Share Posted March 7, 2010 windscreen demister front dash vents? Hi mate Sorry mate I don't have any dash vents at all Cheers Sam Link to comment https://www.sau.com.au/forums/topic/310465-wrecked-r32-skyline-rb20det-parts/#findComment-5121058 Share on other sites More sharing options...
Nissan r32 Posted March 7, 2010 Author Share Posted March 7, 2010 Hey bud i'm looking to buy ecu + wiring loom, airflow meter and maybe the coil packs and igniter. How much $$ and will you post to S.A? Hi mate PM Sent Link to comment https://www.sau.com.au/forums/topic/310465-wrecked-r32-skyline-rb20det-parts/#findComment-5121061 Share on other sites More sharing options...
DuFFR32 Posted May 6, 2010 Share Posted May 6, 2010 Hey mate would you have a passenger side r32 m spec rear pod? ? Link to comment https://www.sau.com.au/forums/topic/310465-wrecked-r32-skyline-rb20det-parts/#findComment-5219620 Share on other sites More sharing options...
Joobie Posted May 7, 2010 Share Posted May 7, 2010 hey buddy, i'll take both engine mounts, pm me your email i can't pm... Link to comment https://www.sau.com.au/forums/topic/310465-wrecked-r32-skyline-rb20det-parts/#findComment-5220988 Share on other sites More sharing options...
pig 32 Posted May 7, 2010 Share Posted May 7, 2010 pics of nismo gear knob Link to comment https://www.sau.com.au/forums/topic/310465-wrecked-r32-skyline-rb20det-parts/#findComment-5221179 Share on other sites More sharing options...
ye.808 Posted May 9, 2010 Share Posted May 9, 2010 pm sent Link to comment https://www.sau.com.au/forums/topic/310465-wrecked-r32-skyline-rb20det-parts/#findComment-5223895 Share on other sites More sharing options...
dewa32 Posted May 11, 2010 Share Posted May 11, 2010 Got radiator support and front reo bar for sale? Link to comment https://www.sau.com.au/forums/topic/310465-wrecked-r32-skyline-rb20det-parts/#findComment-5226691 Share on other sites More sharing options...
pig 32 Posted May 11, 2010 Share Posted May 11, 2010 manual ecu? Link to comment https://www.sau.com.au/forums/topic/310465-wrecked-r32-skyline-rb20det-parts/#findComment-5227330 Share on other sites More sharing options...
Hibino Posted May 28, 2010 Share Posted May 28, 2010 (edited) pics of climate control unit and aircon piping. Does it come with wiring for unit? Edited May 28, 2010 by Hibino Link to comment https://www.sau.com.au/forums/topic/310465-wrecked-r32-skyline-rb20det-parts/#findComment-5260904 Share on other sites More sharing options...
