Up for sale / EOI is my S14 series 1, i built up from full standard spec! ALL MODS WERE DONE THIS YEAR...
-Currently making a moderate 296 rwhp on 18psi tuned by HPR on 3/2/2010
-1994 red in colour
-105xxxkms + logbooks included
-rego'd till march
-Aircon regassed in January 2010
-serviced on 5/2/2010
-motul 4100 turbo lite
-nissan oil filler 5/2/2010
-nissan fuel filter 5/2/2010
-nissan coolant/flush 5/2/2010
-gearbox oil changed 27/2/2010
-new platinum plugs changed before tune
-new nissan water pump
wheels & suspension:
-BUDDY CLUB P1's Fronts 17x9 +27 running 30mm spacer 225/45/17 Rears 17x9 +17 running 30mm spacer 235/45/17
-new lucas brake pads front and rear done 15/1/2010
-D2 coilover suspesion 8kg front 6 kg rear
-diff has been shimmed to a LOCKED state on 5/2/2010 by O1G
-new 30mm bolt on spacers all round
-new extra lock steering spacers
-new rear adjustable toe arms
-new rear adjustable traction arms
-new rear adjustable camber arms
-new rear adjustable sub frame brace
-new front castor arms
-new alloy cradle bushes
-new project mu wheel nuts
Interior and exterior:
-Hks boost gauge
-pioneer cd player and some speakers?..
-5% window tint all round done 10/01/2010
-new suede OMP 85mm dish steering wheel
-new cusco drift button
-new nismo gear knob
-new HID 8000k head light conversion
-new white led parker bulbs
-hand flared rear guards
-series 2 tail lights
Engine and performance:
-new OS Giken twin plate clutch
-new nismo gearbox mount
-new rear main seal
-new bosch 040 intank pump
-new nismo 62 degree thermo stat
-new garret 2876r turbo .63 rear (HPC coated front and rear housings)
-jap made stainless manifold
-new custom 3" alloy lobster back intake
-new custom alloy oil catch can
-braided oil and water lines
-stainless screamer dump pipe
-stainless front pipe 3" cat, full stainless 3" catback (made to sit higher than chasis rails
-blitz intercooler kit
-new Z32 air flow meter
-Apexi airfilter
-new nismo 550c injectors
-new sard fuel pressure reg
-new greddy 1.3 bar radiator cap
-new engine dampener
-apexi power fc PRO
-new turbo smart T-peice boost controller
Asking: $14500
Condition: very good, imaculate interior, straight body, just has clear flaking off boot. GETS SERVICED MONTHLY AT APROX 1500kms
Located: springfield
Contact: Via PM
Edited by drf34
https://www.sau.com.au/forums/topic/310982-fs-bne-nissan-200sx-s14-series-1/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
