just did oil filter,fuel filter,oil and a radiator flush
running lovely
will look at c33 laurels now too
anything uncommon with 4 doors ill have a geez at
interested in 2door gtir at all? plenty of photo's here >>>GTiR Pics
Hey mate... not sure if it's your cup of tea but would you be keen to swap for my S14? I'll sent you an email via carsales.
nah not really lads,although it looks good the gti-r is way too small,same with the s14
ive got a 4month old boy so he needs to get in the back occassionally
still looking for the right car,had plenty of good offers which i nice,just not exactly what im after
the only 2 door ill seriously look at is an AE86
still looking for-
laurel
JZX90/100
cefiro
rotor powered sedan
the stagea is super well maintained,clean,nicely modded,neat and un-thrashed
so offers of similar presented cars would be appreciated
maybe the reason the guy sold it was because he had kids... :thumbsup:
sorry jeremy,i couldnt help myself mate
good luck with your sale
still looking for the right car to replace the stagea
may also look at aristo's
Can't swap for track cars either guys,no time for that stuff at the moment
need a clean,rego'd,and unspanked 4door to replace the stagea
super keen to look at clean laurels or maybe ceffys
thanks for all the offers tho guys
Rodney
Stagea is no longer available
unless you have a mint and legal laurel, I don't want to hear from you
car is now serviced,rocking GTR front seats, and straight pipes aren't far off
also looking into manual conversion
thanks everyone
  • 1 month later...
Thanks to all the lads who are still offering me swaps
stagea isn't really on the market now,UNLESS you have something that really catches my eye
I'd love to keep it,so the offers would have to be pretty good
i got stainless straight pipes,sitc and safc now that aren't installed on the car but will go with it
also now got genuine 260rs sideskirts,and possibly a brand new 260rs front bar ill pass on
price without rims 13500
with rims 14500
will also take a look at swaps for a 32gtr
  • 1 month later...
Gonna bump this up,just to see wats out there now
now has a clutch pedal and master cylinder installed,got a freshly rebuilt exedy button clutch,and have a r32gtr gearbox lined up for a new buyer
plus all the other little bits and bobs that are needed for the conversion
it's basically half done,I've been collecting parts for the conversion for a while now and will be going ahead with it regardless of whether it sells or not
straight pipes are on now too...
would love to get behind the wheel of a r32 gtr,or any uncommon 4door
so offer away your swaps...
Will post some recent pics wen I get home
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia body...
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
