Hey guys,
Well, I drive my car possibly once a month on the road and still managed to receive a cute EPA in the mail... ?
Would be much appreciated if someone nearby could lend me a standard exhaust with cat for a week at the most...
I'm located in Mill Park...
Appreciate your help!
Dean
https://www.sau.com.au/forums/topic/311737-need-a-favour/
Hey guys,
Dean
It's your lucky day. I've got a stock cat back (including cat of course) to suit R33 which I used to pass EPA (tested at 87db I think) at my parent's place in Bundoora.
Only catch= When you return it, It will need to be delivered to my Sister's place in South Morang, which is probably closer to you anyhoo.
Reason being, that my parent's are moving house in a few weeks and I don't have a garage!
Let me know when you want to pick it up :nyaanyaa:
https://www.sau.com.au/forums/topic/311737-need-a-favour/#findComment-5131645
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
