i have a full cage, but wouldn't this make it more stiff?
are you saying you cant install this because of the full cage or you don't need it because of the cage
i dont see why i need it with the cage, after i installed the cage its just been sitting in the garage.i dont see why it cant fit with the cage.
not sure aye, but it will fit a 2door.
Hey champ, as discussed on text i am keen to come get this on the weekend. I will come with cash. Ill give you a call or you can shoot me a PM and give me some more details on where and when suits etc
Cheers
Matt
:D
