Hey ppl.. i know its not a skyline but its a tuff as nails car that was stolen out of mates shed during the day on monday 22.. (yesterday).. 3 middle easten looking people were seen pushing the car down the road where it was roped up behind a white toyota hilux van.. the van has chrome mags and stockies on the back... more info on facebook.. http://www.facebook.com/#!/pages/VK-Ca...89757349?ref=nf..
any info?? please help..
https://www.sau.com.au/forums/topic/313125-4000-reward/
This car belongs to a good mate of mine.
It is his pride and joy. Alot of time and money has been spent on this thing, and altho it is not a skyline we are hoping that someone can help in some way.
Even if the car was to just "turn up" somewhere with a random phone call to him, i am sure he would just be stoked to have it back.
Please if you can help, call Aaron on 0421 755 114.
Many thanks
https://www.sau.com.au/forums/topic/313125-4000-reward/#findComment-5145768
yeh morphett vale mate.. near wiriander high school.. was flat towed away behind the hilux....
shit, i go past there everyday.. will keep an eye out, live 5 minutes away so yeah..
Although i read on facebook it was loaded into an enclosed trailer, at some point? If thats true you probly got no hope of finding it.. :ermm:
https://www.sau.com.au/forums/topic/313125-4000-reward/#findComment-5145920
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
