Hey as the topic states, have a few bits for sale.
1x Bee R rev Limiter, perfect condition hardly used $250
Greddy eo1 boost controller, complete. $300
2x RB26 airflow meters. These are brand new and were purchased from access online. They are factory rb26 afm's with z32 internals. They use the standard wiring harness plugs. $250 for the pair.
All parts are in as new condition
Rev Limiter
Boost Controller
AFM's
  • 4 weeks later...
I can gauratee you they have z32 internals. I planned on using these with a power fc and they were installed on the car, but then i changed to a vipec ecu with map sensor so i no longer need them. They were purchased from access autoworks new and still have there order number and another number on the stickers on each afm if that helps?
I paid $500 for them $200 or thereabouts it would be a far cheaper alternative to take using the original afm plug rather than spending 6-700 or z32's
Rev Limiter sold.
Price drop to $180 bucks for both afm's.
I'll take em :blink: have pm'ed you
also tried to call but didnt get an answer
cheers
-D
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
