i have few parts that i would like to sell as i have no need for them any more
apexi power fc hand controller to suit evo or rx7 in very good condition $170 neg.
greedy cooler pipe. the one that comes straight off the turbo and hooks up to your air filters etc.
came off a t78 trust turbo but im pretty sure will fit any big single turbo conversion. $270 neg.
just jap oil cooler core. $100 firm.
i am aceptting offers but please no low ballers. pictures as above. do apoligise for the quality of the photos phone was playing up.. contact number 0423682131 loky :) located in campbellfield, victoria.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
