Just would like to know ithe seat and open pressures of the type b valve springs for rb25det if anyone knows them could you please let me know becuase on the tomei website it does not have it in lbs its kgf any help would be good thanks.
https://www.sau.com.au/forums/topic/314448-tomei-rb25det-type-b-valve-springs/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
