Hi guys. My car was involved in an accident recently, which fired off the airbags.
I have replacements that I have pulled out of a half-cut, but I have a few questions:
1) Are they safe to handle when disconnected? (i.e: is there ANY chance of them going off?)
2) Are they likely to go off when I put them into my car (which is still being repaired)
3) Do I have to do any fancy ECU trickery afterwards?
4) Do I need to replace any sensors or anything other than the airbags themselves?
Thanks in advance, i'm really keen to get my car back on the road!
-Steve
https://www.sau.com.au/forums/topic/314542-airbag-replacement-can-it-be-done/
my flat mate changed between his airbag wheel and a momo repeatdly for a while and it was happy enough . the light went out when airbag was reinstalled .
yes there is a chance it will go off but its very small but possible . comes down to perception of chance??
obviously what ive said didnt apply to a crashed car .
I'm in a sort of similiar situation...
I have a series 1 33 GTR and thinking of getting the dash airbag for the passenger side.
1) Is it possible to replace the dash with a series 3 or even a gtst one?
2) What if the car doesnt have the wire loom for the sensor?
3) Is it a lot of f**king around (we had a bit of fun when putting a/c on the car initially and found out it doesnt have the a/c loom)?
4) What is required (e.g. dash, sensor, airbag etc)?
Thanks all! Just wanna make sure before I fork out close to 1k only to find out it doesnt work.
OK.. so far from googling I have the following:
1) Disconnect negative terminal of battery.
2) Disconnect airbag fuse.
3) Allow 10 minutes for residual power to dissipate.
4) Replace airbags
5) Re-insert airbag fuse
6) Insert ignition key
7) Re-attach battery clamp
And an old, old SAU thread about pressing the drivers door-light switch 7 times, once per second within 10 seconds of turning the ignition on if the airbag light on the dash stays on or flashes.
God I hope these don't explode in my face! (again)
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
