Hi guys
I am here to sell my 1996 R33 GTS-T Skyline. It is very clean and nice car to drive. The engine is running very smooth, there is no issue at all since I brought. It is an Auto as I never find skyline only been done 49*** from the Odometer and also in this immaculate condition in the market. So during that time I made decision to buy a perfect condition auto then convert into manual by myself. However, I have to upgrade my car into family sedan because birth of my baby recently. The car is being well maintained. It been serviced in every 5000kms or 3 month and washed, detailed in every week. All services are done in Japan link motor where I brought the car from 2 year ago. (Recently, swap to Medias for my friend to look after). All services are using genuine Nissan products. This car never has been on track or drive defensively. It is only a weekend car as I work in city and use public transportation more often. The car comes with Top brand and quality mod parts which includes:
Engine:
HKS Air filter (with plastic cover make legal)
Saber intercooler
Fujitsubo legalis R limited edition 3" Turbo back exhaust
Wheels/Tyres/suspension:
Work Cr Kai (18*8.5 F 18*9.5 R) Gun metal
Tein super street with EDFC
Interior:
Saber gauge (boost and water) in Greedy pillar pod make legally
sony Audio header
Tinted Windows
Exterior:
Full body kits (IMPUL front bar)
GTR wing with CF blade
Extra:
HID system
Turbo timer
Keyless entry
GTR style Key
Price: $17,000 neg
Odometer:49,*** klms (Genuine)
Rego: March, 2011
Only for genuine buyers
Contact: Joe (0422 703 664)
https://www.sau.com.au/forums/topic/316785-immculate-96-yrs-r33-gtst/
Why does everyone think there is only 1 type of 400r front bar. The whole point of the series 2 400r front bar was to retain the factory foglights that came with the series 2 R33's, it even has the same cut outs on the side...
But yeah whatever, clean car.
http://www.uniqueautosports.com/
under bodykits for R33 series 2.
Just because unique autosports decides to call that series II bar a "400R" bar, does not mean it is. Such a thing never came out on a 400R. There was no such "series II GTR 400R bar". Only ever been one type, with more central indicators and big ducts/vents.
nice car free bump :)
Thankx Nacho.
anyway the bar matches side skirts and rear bar perfectly, which makes an aggressively looking!
throw me an offer...price still neg!!
nice car free bump :(
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
