This strarted happing bout a week ago and i dont want to have to put it on the dyno just to find out whats wrong any help much appreciated..
first up my mods are on my r32gtst
mines ecu
splitfires
r33turbo
trust cooler kit
hks pod
split dump and full 3inch exaust and a removed cat(no i did not do that so dont comment on it i no its a shit idea)
tomie fuel reg (no gague)
intank walbro
excedy cushion button clutch 5000k old
my clutch fan ceased and while i was driveing with the shit clutch fan this started happening not sure if its related but yeah
have put a better one on there but still when i drive the car past 5500rpm i get boost creep and with the boost creep comes the dead reving (now when i say dead reving i mean the car keeps reving but the reving slows down and you can feel the power drop off which i dont under stand you would think as the boost creeps the power would rise right
i thought i had faulty actuator which i did the spring was shat and i have changed that boost is more stable but still creeping and still dead reving
i was also wondering if it could be leaning out and the ecu is retarding the timing to stop it detonating i have heard the mines ecu will do this but because of what it just started happening
i thought maybe Bad fuel or maybe blocked filter so i changed the filter and ran fuel system cleaner and it got a lil better but still is dead reving
another thing is the when the engine is cooler and you show the car some love its fine for the 1st run but after that it starts dead reving as the car gets hotter
Could there be something getting heat soaked???
one other thing i thought is that i have plumbed both the breathers on the rockers into a catch tank and then back out the catch tank into
the intake pipe
now the pipe that was going to the pod was heating up and sucking shut which isnt good but has sinced been replaced with better hose and that problem is fixed but it blocking the breathers could that haved fubared a pcv valve or something its a long shot but anythings worthago
sorry for the epic thread BUT I NEED HELP ASAP
https://www.sau.com.au/forums/topic/317054-boost-creep-dead-reavingr32-rb20det/
just a quick question
before you start the compression test do you have to disconnect the electricals like ignition module etc ?
what compression test i have had it done once and that was by my tuning shop
as far as i no you just remove your sparkplug screm your tester in and manually wind the motor over
but not 100% haven done it personally
anyone else can you help me out???
i dont think all do, but theres a fair few i know of that definately do, check it manually and see if its free to swing open... what sort of boost pressures is it creeping to? whoa jason ive never seen the standard map before, that runs a hell of a lot of timing in the mid range at light cruise
yeah will pull it off in the morning and check that i had it set to 12psi on the hks evc 4 but would creep to 14psi but thats gone now and its just running the standard setup and is creeping to 14psi still i will check the dump and let you no how i go thanks guys
j took the actuator rod off the wastgate flap today and moved the flap manually seems with a push down on the flap slightly and try and move it open and closed it gets caught on something like the inside of the dump i will have to pull it off to really find out wats going on
also should there be some up and down play in the actuall flap or should it sit solid i have about 2mm of play???
thanks again
its hitting the middle of the split bit of the dump that seperates the wastegate and turbo exhaust gases, maybe try grinding out enough from the divider so the waste gate doesn't foul on it
yeah i will mate thanks
but y do you reckon its just started doing it????
the car was fine and then one day it just started doing it maybe heat shrink thats all i can think off unless the exauhst is starting to sag possibly because there is no hanger on the after market front pipe???
is there anything else anyone can think off that would cause this
Colder nights?
nah it happens all the time during the day at night whenever it wants
the only time it doesnt do it is the first time you get into it
is it possible my bov could be leaking its a drift vent to atmo its a year old but would the pressure loss under load cause my problem
Thanks again
yeah if it was leaking enough it cause these issues. Can you tighten the spring on it?
it is a drift adjustable one you can just turn the top to hard i will do that tommoro before i go to work it would be great if that was the issue lol
well that isnt my issue gonna take the dump off now check all vacumm lines cant think of anything else it could be
put a standard dump of my rb20 turbo today and there is still a spot on the standard dump where it seems to catch and i stilol have the same issuse i must have soime sort of air leak or something cause i cannot find the issue
Sounds like your timing is retarded?
yeah it feels like that but i dont no why it just started happening
if the CAS(crank angle sensor) is faulty or somehow loose do you think it would cause my timing issues making the turbo boost creep
i have also found a decent exauhst leak from the flanges the cat bolts to under load it would leak a fair bit is it possible there could be some sort of pressure loss or drop causing the boostcreep and timing retarding
I have seen upto 5psi more boost in a GTR with the base timing retarded 12degrees. You need to get it to a well respected tuner because I'm just speculating here. Its the type of issue I would find in 10min on the dyno.
yeah its booked in i just would have liked to have been able to deal with the issue myself but oh well will update shortly thanks
im gonna change the ecu and see if that does anything.
The new ecu i have is an auto one.
now i no you can run a manual box behind a factory auto and bridge the neutral/drive switch telling the ecu its in park not drive but will there be anything on a factory manual loom that will need to be tinkerd with to run auto ecu behind a factory manual car
or will it be plug and play??
this is only to see if my current ecu is working or wheather thats the problem
Thanks
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
