hay guys, iv been doin research on the IBC and heaps of stuff, but not really helping with that im after. iv just installed a gizzmo IBC on my r33 gtst. which has front mount and 3" zorst.
i just cant seem to get what psi i want. im only after 10psi at the moment. i hav duty at 10ish i think and gain at 2.. i stoped it going over 15psi. what am i doin wrong.
can som1 explain how to set it properly. i have read the manual online and still stuck.
what settings should i use? if any1 could help that would be awsum
https://www.sau.com.au/forums/topic/317170-gizzmo-ibc/
set the gain to zero.
then increase the duty up slowly whilst accel in 3rd or 4th (4th better) usually the duty will be between 30 and 35 to achieve 13-14psi BUT everycar is slightly different as the gate pressures vary slightly.
once the boost is set increase the gain until it spikes then come back 5 points.
https://www.sau.com.au/forums/topic/317170-gizzmo-ibc/#findComment-5186532
set gain to 0. and duty at min 10. still goin over 10psi??
check that your solenoid is hooked up correctley. what is the boost run when the solenoid is removed from the circuit? ie boost source straight to the actuator?
https://www.sau.com.au/forums/topic/317170-gizzmo-ibc/#findComment-5189186
with the standard boost controll it was stock. lyk 4psi untill 4500revs than a little bit more
https://www.sau.com.au/forums/topic/317170-gizzmo-ibc/#findComment-5190681
boost to port 3 actuator to port 2 on the solenoid? nothing else tee'd into those lines? they must only go to the solenoid then directley to the actuator. Post a pic of the install.
One other thing is the vacuum source to the main unit kinked or squashed at the firewall grommet?
https://www.sau.com.au/forums/topic/317170-gizzmo-ibc/#findComment-5190774
i will post a pic up 2moro afternoon after work, im pritty sure i have the rite ones. i bascially just copyed the stock ones. but the post to intercooling piping is going where the stock one was, wich is off the plumbed back pipe off stiock bov, next to block above zorst manifold and to left. the line going in2 the unit goes through the passenger gromit, no pinching that i could see. ill post a pic 2moro.
https://www.sau.com.au/forums/topic/317170-gizzmo-ibc/#findComment-5190795
nar turns out plumb back pipe was the problem, so im guesing it would only allow air to get in wen it blew off. its now connected to a T somewhere else and workes perfect. thanx for ppls help
thats what i noticed in the pics, the boost source for the solenoid was in the wrong spot (hookes to std boost controller dump port in the plumb back line)
https://www.sau.com.au/forums/topic/317170-gizzmo-ibc/#findComment-5197104
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
