As part of the FFplenum and front Mount mods, all the existing piping was taken out. And put in a box.
I remembered reading in the SK instructions about DFA fitting that there is an orifice somewhere in the system. I can't find one inall the tubing I took out. Is it necessary, if so where does it go//
Any help please.
https://www.sau.com.au/forums/topic/318272-orifice/
an orifice for what ?
do you mean a spigot out of the piping as a pressure source for something?
all of them are out of the l pipe
are you talking about 20mm air feed to the aac valve?
or is its series 2 it will also have one out of the pipe from ic to tb for the powersteering
https://www.sau.com.au/forums/topic/318272-orifice/#findComment-5201824
Are you talking about the small brass restrictors in the boost solenoid / wastegate vacuum lines? If it is those you are talking about look for yellow bands on the vacuum lines to indicate where they are, if your lucky they won't be worn off. If your running stock boost control they are important.
https://www.sau.com.au/forums/topic/318272-orifice/#findComment-5201848
Definitions of orifice on the Web:
* an aperture or hole that opens into a bodily cavity; "the orifice into the aorta from the lower left chamber of the heart"
wordnetweb.princeton.edu/perl/webwn
* The O-Force is a superhuman mutant team in the Marvel Comics Universe. Their first appearance was in X-Statix #1 and was created by Peter ...
en.wikipedia.org/wiki/Orifice_(comics)
* A mouth or aperture, as of a tube, pipe, etc.; an opening; as, the orifice of an artery or vein; the orifice of a wound
en.wiktionary.org/wiki/orifice
* Orifices - A body orifice is any external opening in the body of an animal. In a typical mammalian body such as the human body, the body orifices are: * The ...
en.wikipedia.org/wiki/Orifices
* An opening or hole.
www.customcooling.ca/pages/dictionary.html
Oh yeah.
You might need to narrow it down some...
https://www.sau.com.au/forums/topic/318272-orifice/#findComment-5202458
    • Welcome!  Any pics of the new GTR? You'd be amazed how many people have minimal plans initially. 🤣
    • Hello all I've been lurking around and reading many threads for quite some time, so I figured I may as well join in. I recently picked up a R33 GTR 3 V-SPEC RISERVATA that’s mostly stock. The car has always been a bit of a dream for me, and now I’m slowly starting to plan the next steps — nothing too crazy yet, but I’d like to keep it clean and responsive while pushing a bit more power.
    • You appreciate it could be pinging and not be audible from inside the cabin on the car right?
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
