The braces that strenthen up the front and bolt on to the door hinges and come forward, will R33 ones fit an S1? If so do they have to be for a 4WD 33? Or, does someone make them for Stageas? I found M35 ones.
Can not really answer your question, but R34 stuff seems to be more of a match on other things
Had a bit of goodgle around
Ultra racing make them. approx $250au for a 3 point R34
It mentions they can be modified to fit R33
My guess they would either fit or need minor mods to fit the stagea as the AWD front end is pretty much R34/R33 suspension geometry hanec the chassis to be similar.
http://www.ultraracingaustralia.com/page18.htm
I bit of more info here how it works
http://www.streettuned.com.au/index.php?_a...;productId=1717
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
