Hi Guys,
Making a new thread with the left off parts from the sale
Brand NEW
RB26 Clear Cam timing cover $100
100mm FMIC to suit GTR Generic/No brand $300
2x Toyo Proxy 18x35x275 BRAND NEW
$500 (retails $500 each)
20x Trust Wheel nuts (Bronze) Very light weight compared to stock nuts
$200
Used Performance Parts
Sard 720cc injectors with Greddy Fuel rail $800 (not seperating)
RB26 Sump with TRUST Sump extentsion welded $700
(Includes R34 GTR diff)
RB26 Clear Cam timing cover (slighly yellow) $60
6x Stock Rb26 rods $150
R33 GTST stock parts
2x Dump pipe $10 each
Front pipe $10
2x Exhaust manifold $20 each
Power Steering bottle $10
SMIC with piping $20
Washer bottle $10
Radiator overflow bottle $10
Pair of indicator lights (clear, front not side) $20
TurboSmart BOV Type 2 $80
Tcc Tech BOV Type 3 $50
R32 GTR boost solenoid $50
6x Stock rb25 rods $50
RB30 head (SOHC) comes with intake and exhaust manifolds $100
PM me with any questions
Located in PERTH but can arrange postage
6 injectors, came off the GTR
less than 10,000 kms
Tyres are proxy 4s
G`day mate! What`s your best price fo the injectors and rail?
For everyone PMing me for best prices
PM me your offer, worse i can say is no
G`day mate ! , Would you take $600 for the 720 injectors and rail? This will bolt on to my R32 gtr?The injector come with spacers to suite?
You know if injector/rail to suit gtr34? (in perth btw)
Edited by Specrzx
Yes it will fit a 32 GTR however it wont come with the spacers
sorry mate, 600 is a tad low
Yes will fit all rb26s
would you take 1000.00 for rail injectors and fmic? if so [email protected]
Edited by nseal14
How about $650 for the rail and injectors? I`ll still have to get the spacers to fit it up. And there is the cost to send it to Melbourne?
  • 4 weeks later...
The rail is still availiable but id rather not seperate it from the injectors
11mm from memory
11mm from memory
Hi, Steve, location?
Does the extended sump come with batfles and trap door,Is the GTR34 front diff different ratio to the GTR33?
you have pm
Tim/Alex
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
