Hey guys,
I have 4 brand new splitfire coilpacks to suit rb20de, rb25de, rb25det, and rb26dett.
I only have 4 as I have misplaced 2 of them stupidly, but my loss could be your gain as Im selling them cheap due to the fact its 4 not 6.
Asking for $250!
These retail at over $600 for 6.
Will suit anyone who wants spares, or who has one or two missfiring and dont wanna fork out lots of money for a set of brand new ones.
Pm me or sms me on 0418 578 922!
Thanks.
Justin.
https://www.sau.com.au/forums/topic/320214-4-x-brand-new-splitfire-coilpacks/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
